2010-03-12 1:12 AM
2011-05-17 1:00 AM
>>I cannot set more than one breakpoint in flash. Is there any trick to set more than one breakpoint ? I use IAR Workbench V5.4 and IAR jLink.
There are usually two, though one is probably consumed so you can start at main(). Sounds like you need to buy a FlashBP license for the J-Link from Segger. You should pursue support for IAR products from your vendor. -CliveWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
