M74HC4094 DS missing STROBE waveform in Timing chart
In M74HC4094 datasheet - DocID1972 Rev 5 - Figure 4. Timing chart, STROBE waveform is missing: JW
Hello CommunityI have somes mcu ST10F275 TQFP144 with Protection Access Enable I need to disable protection I only have Beeprog and ST10F programmer I tried to write Access Protection Register using Beeprog programmer in order to disable protecti...
Hi,Iam using ST485ERBDR RS485 chip on my CNC controller card. In the datasheet I see that the Min data rate supported by the chip is 2.5Mbps.Please can anyone confirm what is the max Data rate it supports.
Currently, I am working on a project that involves STU HF library, it works fine on the .net framework project. However. as we move on to the .net core project to branch out to other operating systems(Linux), the project could not read stuhfl.dll. My...
I know that this IC: ST10F252-ABG is old, but is there any cross or direct replacement for it?Thanks,Byron
Hi,Is there any utility available from st to test EEPROM?Thanks in advanceSurya
Posted on September 03, 2015 at 12:41Dear all,I would like to export the current design project by Viper06 and Viper16 to PSpice, but the ''export button'' is greyed...In your eDesignSuite Video, you also explain the ''save functions'' with a Viper...
Do you have a data sheet for this product? Has this product been discontinued? Is there a reference for alternative part numbers
Hi everyone,I am working on a LTSPICE model for TL062 I think maybe you can help me :)This is the schematic diagram is the datasheet :and this is my spice model To test if my amplifier is working i am trying the basic utilisation for OpAmp : So I con...
Hello , Can you help me for the microntroleur reference 1) Why don't you recommend this product for new designs ?2) Do you have an idea of the number of years before the end of its life ?3) NRND information available in an PCN ? Thank you in advance
