Others: hardware and software
Should we hope for long-term use of stm8?
Posted on October 12, 2017 at 14:20Hello everybody,Recently, the company has been actively offering to transfer your projects from 8-bit micro-controllers to 32-bit ones. In view of this, I had concerns about the feasibility of future developments w...
Enabling ROP in application?
Posted on November 08, 2017 at 07:47Hello. Is it possible to enable ROP in application? Let's say I transmit a command to MCU through UART and then MCU enables ROP. I am using STM8AF6223.It is stated in PM0051 that 'readout protection is enabled by ...
STM8L051F3P6 bootloader USART pins
Posted on October 20, 2017 at 09:25Hello! What USART pins of STM8L051F3P6 are dedicated for bootloader, PC5-PC6 or PA2-PA3? Can't find any info about that.The same question about stm8l151c6.Thanks!#bootloader #usart-pins #stm8l051f3
EvgenS Po by Associate II
  • 1493 Views
STHV800 rx amplitude problem
Posted on November 06, 2017 at 13:47Hello CommunnityI use the eval board STEVAL-IME013V1Input frequency 40kHzTransmission of a sin 40kHz signal from XDCR8 to LVOUT8 1:1When the piezoelectric element UTR-1440K is switched on to the XDCR8 connector, t...
[ATT]9960
Posted on October 23, 2017 at 19:44Problems counting pulses between 5hz-100hz on STM8s003f3p hikindly help my design.     i am using stm8s003f3p micro-controller. timer 1 input capture unit doesn't work as i intended. i searched web forums and blogs...
