SPV1020 is discontinuet, does ST offer an alternative part ?
Posted on March 14, 2017 at 17:38The SPV1020 seems to be discontinuet. Does ST offer an alternative part ?
Hi,I am trying to program the option byte in STM8S003 controller. I am able to do the same using STVP tool. It is not a practical method on production, so want to add the option byte config in the source code. for that I added the below code snippet....
Is there any code initialization tools for STM8s MCU.Kindly share the details
i have configured spi in polling method.I have loaded the data into the transmit buffer and waited for TXE flag to be set.Unfortunately the flag is not being set and what could be the possbile reasons for that?I have attached the code configuration b...
STVP seems to program my STM8A discovery just fine. Just started with STM8 but I'm a long time Keil, CCS, Xtools user and I'm finding this environment a little haphazard.
I have used stm l4984d ic for pfc control and got all the necessary parameters within range but still no pulse is generated by pfc ic. What can be the possible errors In my design so that I can rectify them
Hello!RM on the STM8S003: https://www.st.com/content/ccc/resource/technical/document/reference_manual/9a/1b/85/07/ca/eb/4f/dd/CD00190271.pdf/files/CD00190271.pdf/jcr:content/translations/en.CD00190271.pdfI see on the page 54, FLASH_FPR/NFPR registers...
Hello!If I separate stm8svldiscovery from it's stlink, do i need to do anything else, other than solder a 16MHz oscillator on the second part of the board?STM8SVLDISCOVERY board: https://www.st.com/en/evaluation-tools/stm8svldiscovery.htmlI know that...
In Active halt mode 3v it is consuming 11uA This is fine. As we increase the voltage above 3v the current gradually increasing 3v ------->11uA3.3v------>80uA3.6v------->195uAAs per datasheet in Active halt mode it should consume 0.9uAPlease suggest...
Greetings!I'm currently working on a project where I've taken over code for a produce that uses the ST72F321BR9 micro. This is the first time I've worked with this chip. In the past, I worked strictly with ARM core processors.I'm trying to figure o...
