Others: hardware and software
Resolved! SPV1040T DC-DC boost converter circuit recommended by the eDesignSuite under solar battery charger is not working...!!
For the project I am doing, I have to make a solar charging circuit. So, I chose SPV1040T as a DC-DC boost converter. For this feature, I used eDesignSuite to create a solar charging circuit. The circuit should convert the 3v from the solar panel in...
Rambo_VK by Associate II
  • 3568 Views
I am working on PWM signal and the following code is not responding properly. Can someone explain where I am making a mistake. I need to generate pwm signal on PB0 (timer ch1)
/* MAIN.C file *  * Copyright (c) 2002-2005 STMicroelectronics */#include <iostm8l.h>#include <stdio.h>#include <string.h>#include <stdlib.h>#include <stdint.h>#include "defs.h"unsigned int count = 0;unsigned int pwm_duty = 0x0000;void TIM2_SetCompar...
VSrin by Associate II
  • 860 Views
