Others: hardware and software
UART transmit reacive is not working
Hi,I am using stm8s105c6 for UART transmit receive program. I am using Eclipse with SDCC compiler.I am getting error as?ASlink-Warning-Undefined Global '_TIM3_CAP_COM_IRQHandler' referenced by module 'main'make: *** [main] Error 1Hope someone will gu...
Ajadh.1 by Associate II
  • 1995 Views
STM8S001J3M enter SWIM mode problem
Hello,I want to program the device using SWIM interface, The host is FPGA, but the device can't response successfully.When I reset the SWIM, the return value is wrong, and write SWIM_CSR could not successfully.I attach the wave form picture, please h...
XLi.3 by Associate II
  • 3517 Views
Can I swap TX & RX USART1 STM8L152
Hi Everyone,I have an issue with USART1 where my board designer mixed up the TX and RX pins going to an external module. Is there any way to swap them in software? I've had a look though the reference manual and seen the remapping feature but its not...
TConl.1 by Associate II
  • 3061 Views
How to handle interrupt on any GPIOs on STM8L152C6?
Hi,I am using user key and three more keys to do some work.Can you please guide me how to assign for the interrupt handler function for particular interrupt on a GPIO?e.g. I couldn't understand:What does the numbers like 8, 9, 10, 11 ect represents i...
AKUMA.2 by Associate II
  • 1119 Views
M41T93ZMY6F RTC resets at negative temperature
1. Can you tell us why this RTC reset happens only in the negative temperature?2.Also,during battery powered ON condition,does the leakage current Loads through RTC supply(VCC) causing a voltage Dip in the battery voltage? Dear Sir/madam,We are using...
ANell.1 by Associate
  • 1711 Views
