can i know the x-ray for item SM6T6V8CA based on DC22+?thanks
Hi, Could you provide :the TJmax (maximum Junction Temperature), RJA(Junction to ambient Thermal resistance), Rjc (Junction to case ) and Rjb (Junction to board / bottom) of M24C16-FDW6 EEPROM.Thank you in advanceRegards
Hello,I am trying to repair a DELL H525AF-00 power supply that contains the CL2183 management IC. Could I get the datasheet for this IC?
Can some one be so kind to let me know the difference between those 2 regulators?Is it bending angel of the pin or the SPQ?Thanks
Hello, I am studying the STM8S208RB MCU and the SPL. I am using STVD and COSMIC, and the Nucleo-8S208RB board for testing. The below code should configure port GPIOC Pin5 and set it to high and stay high. However, LED2 turns on for only a short momen...
Trying to fix Dell 2709Wb with power issue. The micro is the all-in-one FLI30366, with 416 pins in a PBGA format. I can only find a summary datasheet, not a pinout. Where to find datasheet with pinout of this chip?This is only thing I have found alld...
