I need to Pspice Model of ST1CC40. Could you help me?
I need this Pspice model to test the performance of this chip on an array of LEDs
I encountered a problem with inconsistent internal structure and marking for the same part number.We only found a document with such a problem.But it isn't suitable for this time.The document was published in 2014. It only mentions "T" and "K". But ...
I was simulating this design, and the eDesingSuite gave me a solution (attached image) that I tested. When I tested the design, I found that I have a 4Vpp ripple, so that's not matching with the eDesingSuite simulation.Does any tell me what could be ...
Hi,I have used Stm8 controller and I have change the keys from OTAA to ABP. In OTAA mode I have get the joining uplink(first uplink) but i didn't get the joining uplink in ABP. When I reset the device after get the second uplink in the network se...
I have a main board with an STM32 uC which communicate with multiple STM32 uC daugtherboards over SPI. I currently use standard male pin headers on the top of the main board, and female socket connectors on the bottom of each daughterboard. The re...
