Others: hardware and software
ISM330DLC gyroscope measurement problem
SpoilerHello, I am trying to read the measurement results from the gyroscope sensor of ISM330DLC, but the reading values keep returning to the initial value due to some sort of reaction that cancels out the reading values. Below, I present the graph ...
deddy11 by Associate II
  • 878 Views
Resolved! VL53L4CD won't init
I'm trying to use a VL53L4CD with a micro.  BTW the platform.c file is wrong.  It says byte swapping is required for big-endian processors.  In reality byte swapping is required for LITTLE=endian processors.  Got past that and a number of other mista...
Wilton by Associate
  • 1624 Views
Old datasheet vb016 coil driver
Hello Im looking for an old datasheet for the coil driver used In automotive application VB016I have find some VB0xx series’s datasheet for others models of coil drivers but not mineIf anyone have it or know where I can find.. :)thanks mickael
Mika83 by Associate
  • 851 Views
PD57060
I found a conflict in the datasheet of PD57060. Or I understand it wrong. Could any of you kindly clarifying the confusion for me.In datasheet page 4, the gain is about 14.3db when the device operated at 945Mhz. In datasheet page 12, the |S21| magnit...
SiC MOSFET with multiple bondwires
Hi,I would like to know which type of this company's SiC MOSFET product has multiple bonding wires and the case can be opened by chemical etching. I would like it to be a single chip and not a module.Can anyone give me some advice on this please? Tha...
THuan.6 by Associate
  • 1205 Views
