Others: hardware and software
USB002 demo code download
Hi all,we have a P-NUCLEO-USB002 kit, and there is a pre-programmed demo image on kitthe demo image will output CLI to operate, (please refer to the attached picture.)but there is not found in the STUSB010 library.could you share the information of w...
qqGHUAN by Associate II
  • 2206 Views
Cant download X-CUBE-SUBG1
I can't download the X-CUBE-SUBG1 library from the link:https://www.st.com/en/embedded-software/x-cube-subg1.html Other things download without problems.
mJar by Associate
  • 1126 Views
binary and invert converion
i am sending data on serial is 3 when is display is this 3 but i can conver in bninary then become 00110011 instead 00000011.and when i invert it then i got 01100110 instead of 11111100 ,why so ?
MCU - suggestions
Hello STM!GOOD Day,We are looking new MCU for VOIP[voice over Internet protocol] project that can handle Internet connectivity and Communications like[ADC,UART] [,LAN, WAN, FXS, FXO support]. and  we are looking HIGH speed  MCU.  Thanks,Hari.
hT.1 by Associate
  • 1444 Views
STM32 Compile Error!
StmCubeIDE içinde yazılım esnasında kullandıgım cubeMX den bacak degişimi yaptıgım zaman, derleme sonrası sadece ana sayfa üzerindeki (main(void) içindeki...) kodlarım neden siliniyor?
tayfun34 by Associate
  • 1442 Views
Resolved! USB issue with STM32F411
This has nothing to do with EEPROM devices, but that was the only "labeI" that would work. I built a custom board using an STM32F411RET6. It has a 12MHz external clock. I'm trying to use a VCP USB interface. The USB code enumerates fine on a 'F407 DI...
marcmign by Associate
  • 2691 Views
