2005-04-26 10:55 PM
2005-04-26 10:55 PM
I want to use the arithmetic functions of the DSP library to optimize a controller function. Does the involvement of the MAC unit really give an advantage in time. e.g the normal operation c=a-b where a,b,c are of type int takes 10 instruction cycles but the use of sub_16(...) of the library uses also 10 instruction cycles (see pdf file) How can I use the DSP library to optimize a function which uses fix point variables? Thank you very much for your support. :-? ________________ Attachments : st10dsplib.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I09Y&d=%2Fa%2F0X0000000bYl%2F0byxZpz9AZLhKONDkJZ6sc8Yys0igbqbc2srhndW4mw&asPdf=falseWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
