2023-05-19 5:32 AM
Q&A - webinar "In-sensor monitoring with intelligent MEMS sensors"
2023-05-19 5:54 AM
The ISPU can process data at the maximum ODR of the accelerometer and gyroscope sensors, that is 6667 Hz. However, you should also consider the processing cost of your algorithm and consequently what is the maximum processing rate that you can achieve.
2023-05-19 5:54 AM
