2020-09-28 10:33 AM
The enclosure this will be going into will be sealed and any humidity present during the manufacturing process will be trapped within the enclosure. Is there a humidity spec we should be aiming for?
2020-10-05 4:10 PM
If you read the datasheet, they say "Moisture sensitivity is level 3 (MSL) as described in IPC/JEDEC JSTD-020-C". I have no idea what that is or where to find it, but I'm guessing it will answer your questions. If not, ping me again and I will dig deeper.
