2018-03-24 6:24 AM
The user manual mentions using one 88% reflectance target and 17% reflectance target for calibration. I don't know what material has those reflectance values. What exactly should I use for calibration and where can I get those?
2018-05-07 4:26 PM
It’s called Munsell Color Paper
X-rite Inc
4300 44th street S.E.
Grand Rapids, Mi 49512
Tel 877-888-1720
The stuff is expensive. Like $26 per sheet expensive.
We use 5%, 17%, 42% and 88% reflectances in our testing. One color per sheet.
MUNSEL NOTATION N2.75/
STM275MA4
5% REFLECTANCE
STMN475/MA4
17% REFLECTANCE
STMN95/MA4
88% REFLECTANCE
STMN675/MA4
42% REFLECTANCE
But standard Photo grade white paper is close enough to 88%, that it will work unless you are really particular.
Black spray paint is 5% reflective. Use a couple of coats. Doesn't matter if it's flat or gloss.
I don't have a good source of 17% gray.
2018-03-24 2:07 PM
Have a look at this lecture presentation:
https://www.cs.cmu.edu/afs/cs/academic/class/15462-f09/www/lec/lec8.pdf
Also, Wikipedia offers quite good explanation:
https://en.wikipedia.org/wiki/Reflectance
However, I wasn't able to find some online trustworthy database of reflectance of various materials.
David
2018-03-24 10:25 PM
Thanks David! The two links you posted explained what reflectance is pretty well. It sounds like the white target is probably something opaque and with a smooth surface finish. And the dark target is probably something with a rougher finish?
I found this chart on Google. I don't know how trustworthy this is but I thought it was interesting enough.
2018-03-25 8:46 PM
I've found this sentence from the VL53L0X datasheet (under 'Performance' -> 'Measurement Conditions'):
Reflectance targets are standard ones (Grey 17% N4.74 and White 88% N9.5 Munsell charts).
So it seems like the targets are Munsell color cards. Now the problem becomes how to get those color cards... A quick search online only reveals small pocket sized color cards, which is probably not big enough...
2018-05-07 4:26 PM
X-rite Inc
Tel 877-888-1720
STM275MA4
5% REFLECTANCE
STMN475/MA4
17% REFLECTANCE
STMN95/MA4
88% REFLECTANCE
STMN675/MA4
42% REFLECTANCE
