2023-12-06 6:36 AM
I am using the STHS34PF80 sensor with the TMOS10-12030 lens from Fresnel Factory. Does anyone have the transmittance % for wavelengths 5um-20um?
Thanks
2023-12-08 4:10 PM
This forum thread was marked by the moderator as needing a little more investigation, so a Support case was created in your name and will be handled off-line.
2024-09-17 1:43 AM
Hello jkutteh ,
Did you get the TMOS10-12030 e transmittance ?
2024-09-17 2:50 AM
According to this document https://www.fresnelfactory.com/fresnel_list/en_poly_materialofFresnel.pdf, it seems that the transmittance is 42.81% (because the material of the lens is Poly FIR 200) but I also would like to be sure if I am not wrong.
In addition, in a https://www.st.com/content/ccc/resource/technical/document/application_note/group2/cb/74/5a/92/c0/de/4a/94/DM00914720/files/DM00914720.pdf/jcr:content/translations/en.DM00914720.pdf datasheet (p.14),you can find a 'tutorial' to compute the transmittance. You need to make acquisition without and with the lens, save TOBJECT and use this formula
