2020-05-11 6:13 AM
2020-05-12 2:50 AM
We call vibration sensors accelerometer products with higher measurement bandwidth like IIS3DWB, but it is not only this. The vibration sensing applications also require higher temperature range +105degrees, temperature stability so in general KPIs we were highlighting in the webinar (low noise, flat and wide frequency response, stable sensitivity over temperature, high out of the band signal attenuation)
