2020-05-14 4:22 PM
Need velocity random walk, Allan Variance for Accelerometers in ASM330LHH. The info is missing from the datasheet.
2020-05-15 7:57 AM
Hi @Ishan.1 , which is the specific application? Please note that the Allan variance is not present in the datasheet because it is not a parameter tested in the production line, but I can share you some characterization data for velocity random walk parameter, that refer respectively to X, Y and Z accelerometer axis:
