2019-05-31 6:49 AM
I was playing around with Unico and I saw it has an inclinometer function. Is the code for that window available:? I tried an implementation with Kalman filter, but the Unico seems to show the angles much better.
Regards,
Gabriel
2019-05-31 8:45 AM
Hi Gabriel, welcome back. Unfortunately the source code for Unico is not available... You could however manage to implement the inclinometer function using the Tilt detection using the MotionTL middleware library of the X-CUBE-MEMS1 (here). Regards
2019-05-31 8:49 AM
Hi Eleon,
Unico uses the same middleware?
Regards,
Gabriel
2019-06-03 4:03 AM
yes Gabriel, almost similar. Sorry for my question, but are you interested in the algorithm results or in the graphical rendering of the inclinometer measure? Are you finding some lack of accuracy in using that libraries? Regards
2019-06-03 4:06 AM
Hi Eleon,
I am intrested in the algorithm, not the GUI. Tomorrow I will try to use MotionTL and see how it goes. Actually, I need it in Python, but if I have it in C I can just convert it.
