2019-04-13 6:12 AM
Hi,I have a problem when develop with LSM6DS3.
After config the active/inactive event to INT1, keep still, the interrupt(inactive event) will happen ,if i do not read 6-axis sensor data.
When i read the 6-axis sensor data every 100ms by a timer callback, also keep still, the interrupt never happen.
I want to know the reason that interrupt do not happen, if i miss anything in datasheet ?
2019-04-14 11:06 PM
Problem has been solved. Do not set the sensor into power down mode when read 6-axis sensor data every 100ms by a timer.
2019-04-14 11:06 PM
