2020-01-27 9:00 AM
Hello, I would like to know if it is possible to solder the LIS3DHTR sensor with the vapor phase soldering process. I still checked the TN0018 document but couldn't find any hint.
Thank you!
2020-01-28 2:42 AM
Hi @CPuru.1 , yes it is. In general, the vapor phase soldering process is not recommended for sensor with holes that connects the inner package volume to the outer environment, such as microphone or pressure sensor, but for accelerometers and inertial modules it is ok. Regards
