LIS2DWT12 4D/6D Recognition
Mcabe.1
Associate II
1 ACCEPTED SOLUTION
Accepted Solutions
Eleon BORLINI
Hi @Mcabe.1​ ,
I cannot see the content of your question, if any...
I suggest you to check the lis2dtw12_orientation.c code on LIS2DWT12 Github repository. The procedure is the following one:
  /* Set full scale */
  lis2dtw12_full_scale_set(&dev_ctx, LIS2DTW12_2g);
  /* Configure power mode */
  lis2dtw12_power_mode_set(&dev_ctx, LIS2DTW12_CONT_LOW_PWR_LOW_NOISE_12bit);
  /* Set threshold to 60 degrees */
  lis2dtw12_6d_threshold_set(&dev_ctx, 0x02);
  /* LPF2 on 6D function selection. */
  lis2dtw12_6d_feed_data_set(&dev_ctx, LIS2DTW12_ODR_DIV_2_FEED);
  /* Enable interrupt generation on 6D INT1 pin. */
  lis2dtw12_pin_int1_route_get(&dev_ctx, &int_route.ctrl4_int1_pad_ctrl);
  int_route.ctrl4_int1_pad_ctrl.int1_6d = PROPERTY_ENABLE;
  lis2dtw12_pin_int1_route_set(&dev_ctx, &int_route.ctrl4_int1_pad_ctrl);
  /* Set Output Data Rate */
  lis2dtw12_data_rate_set(&dev_ctx, LIS2DTW12_XL_ODR_200Hz);
-Eleon
P.S.: I received an automatic e-mail with this content. Can you please confirm me it is the correct one?
Good Morning,
I'm trying to use 4d/6d recognition for a project. I configure the accelerometer registers like this:
Reg 25h = 0x00
Reg 3Fh = 0x21
Reg 35h = 0x60
Reg 34h = 0x08
Reg 23h = 0x80
Reg 30h = 0xE0
Reg 20h = 0x20
In register 30h I enable 4D detection, in register 3Fh I enable interrups and in register 23h I route 6d recognition to INT1.
When I faced up or down the accelerometer and read the status register (27h) I don't see that a change position event is detected.
Does anyone know what is wrong with the accelerometer configuration?
2 REPLIES 2
Eleon BORLINI
Hi @Mcabe.1​ ,
-Eleon
Good Morning,
Reg 25h = 0x00
Reg 3Fh = 0x21
Reg 35h = 0x60
Reg 34h = 0x08
Reg 23h = 0x80
Reg 30h = 0xE0
Reg 20h = 0x20
Mcabe.1
Associate II
Yes, thank you. I change my configuration and works
