LIS2DW12 built-in temperature sensor
meco
Associate II
Hi all,
Could you please tell me if the temperature sensor of the LIS2DW12 is used to correct the acceleration sensor?
Thanks all,
1 ACCEPTED SOLUTION
Accepted Solutions
Hi @meco ,
No, the temperature sensor is not used to correct the accelerometer outputs.
4 REPLIES 4
Federica Bossi
Ciao @meco ,
What do you want to correct for the accelerometer?
hi Federica
Can you please tell me whether the output of the built-in temperature sensor is automatically used to correct the output of the three axes (X, Y, Z)?
Thank you
Hi @meco ,
hi Federica
Problem solved Thank you
