2016-04-15 10:22 AM
Is the INT1 pin of LIS2DH12 set to push-pull configuration per default? And if so, is it possible to set it to open-drain?
Note: I already set the INT1 to active-low - but open-drain would be necessary as well...We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
