2023-01-23 7:56 AM
2023-01-23 12:28 PM
Welcome, @BSeeg, to the community!
you can use the command *setvddio3.3 to set VDDIO=3.3V. This and all other commands are listed in UM2116.
Hope that helps?
/Peter
2023-01-23 1:00 PM
Hello Peter
Is there a way to send comands in the unico Gui?
I tested The UART Interface and only the command
"*list"
did somthing
the Command
"*setdbMKI195V1" to select the LSM6DSRX Sensor i use got an
"inf Adapter nor supported" response
The conds *setvddio3.3 or *setvdda3.3 changed nothing nor got an response.
best regards Bene
