Troubleshooting required with STM32f4 USB Microphone device
Posted on November 15, 2013 at 14:41Dear all,I think I am almost done with the this program, but when I plug after pprogramming my STM32F4 Discovery board. It gives an exclamation mark, (Code 10) generally. ''The I/O request was canceled.'' is writt...
contact2 by Associate II
  • 7686 Views
  • 16 replies
LIS3MDLTR
Posted on March 28, 2014 at 14:02Hi, I received a couple of LIS3 samples last week and I'm using them in order to gain a little experience in the field of magnetometers. I managed to install the chip on top of a plastic pen in order to use it as a m...
adelmo by Associate
  • 790 Views
LIS330D Adaptor & STEVAL-MK 109V2
Posted on March 28, 2014 at 05:47I recently purchased the above. I am using Windows & software and wish to evaluate this product. Is there a datasheet, software, etc that applies to this? Thanks Peter
martech by Associate II
  • 663 Views
self test mechanism
Posted on March 28, 2014 at 03:13Hello, I am new to ST accelerometers.And I am interested to LIS3DE or LIS3DH.I would like to know the mechanism of the self-testing mode.Anyone can help to send me a link of ST site, so I can learn from that?I tried ...
k2 by Associate
  • 838 Views
Accelerometer LSM303DLHC-Interrupt is not working properly
Posted on March 21, 2014 at 14:34Hello,I am using accelerometer LSM303DLHC.I have made following settings:-1)      2g mode and data rate of 25Hz in normal mode.2)      All configuration register set as per initial requirement of accelerometer.3)    ...
purchase by Associate
  • 1009 Views
iNemo-M1 sample code
Posted on January 29, 2014 at 18:47Hi,after installing and compiling the iNemo Libraries, I wanted to know if there are any code samples relating the M1 module, even simple ones.Thank you #inemo-m1-sample-code
franz by Associate
  • 1648 Views
configure LIS3DSH for different ranges
Posted on March 20, 2014 at 15:26Hello,I'm trying to work with LIS3DSH device with different ranges.I put the device on a table facing up, so Z axis should give me 1000mg reading, for all ranges.I configure the device to range 2g by writing to reg_5...
zoharr by Associate II
  • 876 Views
lsm303dlhc calibration issue
Posted on March 20, 2014 at 08:48Dear sir/Madam, we are using lsm303dlhc. we don't know how to do calibrations .we are not understanding scale factor , offset and misalignment . so , i request you please give me the clear information regarding this ...
LSM303DLHC IS NOT WORKING IN PROPER WAY
Posted on March 18, 2014 at 13:57we are  working with lsm303dlhc compass sensor and  interfacing with lpc3250. we are using linux kernel version 2.6.34. and have taken driver codes (accelerometer and magnetometer) from your site. its working only on...
