external clock
Posted on November 30, 2015 at 10:39hi, can someone tell me how to configure the external clock on inemo?i can see there is an oscillator on inemo, so how can i use it? thanks
mauro2 by Associate II
  • 588 Views
inemo tutorial
Posted on November 24, 2015 at 12:17Hi, i'm trying to develop a simple application with steval-mki121v1 , the inemo board. I just want to acquire data and blink a led using a GPIO, fixed a threshold.Can someone tell me if there is a guide to begin t...
  • 734 Views
So does the LSM6DS3 support SPI or not?
Posted on August 13, 2015 at 22:22Didn't see a way to delete this post, so just overwriting it...Finally got the LSM6DS3 to work over SPI. Was just some loose connections that didn't seem to bother any signal except the chip's SDO, which is still so...
lee23 by Associate II
  • 1080 Views
lsm303d impact recognition
Posted on November 20, 2015 at 19:23I see that lsm303d has an application of impact recognition. How can this be known? What sensors or what registers would be triggered on an impact that we can get to know?
anoop2 by Associate
  • 917 Views
how to layout mp34dt04?
Posted on November 18, 2015 at 10:23Do it need multilayer for mp34dt04 layout?Can you give me some reference?
kai1 by Associate
  • 704 Views
Power down gyros?
Posted on November 17, 2015 at 19:33Is it possible to somehow power up only a single gyro rather than all 3? I only need the gyro on one axis to detect the motions I'm looking for, and I could really use the power savings.
  • 832 Views
Sonar like algorithm
Posted on November 07, 2015 at 16:45 Hi guys, I am trying to read a sensor that is rotating, then record all the values through the ADC and I want the sensor to stop rotatin when it found the hishest value. Do you guys have any idea ho...
raw_pix by Associate
  • 874 Views
LIS3DH FIFO Int generation
Posted on June 12, 2015 at 22:27Hi all,I am trying to use my LIS3DH in FIFO Stream mode.I am trying to configure the accelerator to generate an interrupt whenever the FIFO is full.However it never generates any interrupts.I have configured the regis...
peyman by Associate
  • 831 Views
Unexpected step change in LPS25H Pressure
Posted on November 04, 2015 at 15:37I'm using the LPS25H pressure sensor and have noticed a strange stairstep behavior where one LPS25H seems to step or jump 10-20 Pa for several minutes to a few hours, then jumps back.  This behavior is quite diffe...
