LIS2DW12 Anti Tampering Application
I need to develop an application of anti tampering using LIS2DW12 and it's interrupt function. I'm using ST's official library and functions from:https://github.com/STMicroelectronics/lis2dw12/tree/f352aa6ab62e4f050948cbbc78f5b79163a42379I have alrea...
GBaue.2 by Associate
  • 1492 Views
Resolved! Is it possibe to visualize the MotionFX function definitions?
Hi Community!I want to replicate a sample application that uses the MotionFX library and I saw that it is present a header file called motion_fx.h with several function declarations that I can use in my application but I cannot see their definitions,...
VNava.1 by Associate III
  • 1331 Views
Dear ST Community, I am currently trying to setup a Finite State Machine (FSM) for the LSM6DSO32. Is there somewhere an example?
I'm using the NUCELO-G071RB with the STEVAL-MKI215V1. I tried to use the example code for the LSM6DSO available on github: https://github.com/STMicroelectronics/STMems_Standard_C_drivers/blob/master/lsm6dso_STdC/examples/lsm6dso_fsm.c, since I did no...
THäck.1 by Associate II
  • 3419 Views
LIS2DW internal Anti-Aliasing filter 1. what order of filter is Anti-Aliasing filter? what's the cutoff frequency of attenuation band? What is the attenuation in the stopband?what's sample rate of internal ADC?
Backgroud: i'm hardware engineer and work for SKF. we used your Lis2DW in our product to test speed of metro.Issue: we found some noise siganl or high Freq. aliasing add in collected data in low frequency. In LIS2DW user guide manual, i find some dec...
vwu.11 by Associate II
  • 3407 Views
