2021-11-16 9:18 AM
I have already tested this devkit on LoraWan Network (Objenious) and it works perfectly with Lora Expansion Cube IDE. Now I try to connect it with the SigFox Cube IDE extension but when I press the button, it sends data (read on COM port) but cannot enable it on the SigFox backend as if the message did not leave. The lights remain on the board. Has anyone ever run this board with the SigFox pushbutton expansion kit on CubeIDE? My device is recorded with PAC and DeviceID on my sigfox's backend and is waiting message to activate token.
