2017-08-31 3:55 AM
I have a couple of weeks trying to make a TLS connection and it has been practically impossible. I am using the SDK for SPWF04A (STM32CubeExpansion_WIFI1_V3.0.2) on a NUCLEO-F401RE, and compiling the code into IAR. I followed all the steps explained in document AN4963 and UM2114. I have tried to obtain the root certificates (CA) of the sites that I have decided to test, and the respective Subject Key Identifier of each certificate. I have placed CA certificates in the code as text string in PEM format and exported from Google Chrome, and I proceeded to do the tests in two modalities, either using sockets, or using the http client.
The issue is that if I establish a socket or http connection to port 80 and without using encryption in the selected test sites (Googleapis, Restipsum, etc) the connection is satisfactory and I get the expected data. On the other hand, if I try to establish the connection in TLS using port 443 for each of these sites, and using its respective certificate and Subject Key Identifier, the connection generates error, usually the errors are: X509 Error 23 (maps.googleapis.com) or X509 Error 19 (restipsum.com).
Here are two examples of console output from NUCLEO-F401RE, in this case, looking for connection to 'googleapis.com' and 'restipsum.com'. They are the standard messages of the example 'Client_Socket' plus some additions that I have added into de code to make it more informative. The presentation of the Certificate and Subjetc Key is for verification purposes.
I would like to know what possible error I am committing, or, if it is a problem in the firmware of the module.
Example output: googleapis.com
-------------------------------->>model number is SPWF04SA
>>Setting CA certificate>>UART TX buffer: AT+S.TLSCERT=content,2+S.TLSCERT=content,2-S.Clean-S.OK<<OK>>UART TX buffer: AT+S.TIME=1504170338
+S.TIME=1504170338-S.OK<<OK>>UART TX buffer: AT+S.TIME+S.TIME-S.Date:17.08.31:00-S.Time:09.05.38-S.OK<<OK>>UART TX buffer: AT+S.TLSCERT=Ca,1235
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----+S.TLSCERT=Ca,1235
-S.No SubjectKeyId-S.OK<<OK>>UART TX buffer: AT+S.TLSCERT=Auth,40
c07a98688d89fbab05640c117daa7d65b8cacc4e+S.TLSCERT=Auth,40-S.OK<<OK>>UART TX buffer: AT+S.TLSCERT=content,1
+S.TLSCERT=content,1-S.List-S.CA:1-S.Cert:0-S.Key:0-S.Id:1-S.OK<<OK>>TLS set certificate OK
>>UART TX buffer: AT+S.SOCKON=maps.googleapis.com,443,NULL,s+S.SOCKON=maps.googleapis.com,443,NULL,s-S.Skip CA-S.Skip CA-S.Skip CA-S.Certificate Error:23-S.ERROR:74:Failed to open socket>>ERROR!Status = 13>>Socket connection error Example output: restipsum.com-------------------------------->>model number is SPWF04SA
+S.TIME=1504170338-S.OK<<OK>>UART TX buffer: AT+S.TIME+S.TIME-S.Date:17.08.31:00-S.Time:09.05.38-S.OK<<OK>>UART TX buffer: AT+S.TLSCERT=Ca,1219
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----+S.TLSCERT=Ca,1219
-S.No SubjectKeyId-S.OK<<OK >>UART TX buffer: AT+S.TLSCERT=Auth,40c4a7b1a47b2c71fadbe14b9075ffc41560858910+S.TLSCERT=Auth,40-S.OK<<OK>>UART TX buffer: AT+S.TLSCERT=content,1
>>UART TX buffer: AT+S.SOCKON=restipsum.com,443,NULL,s+S.SOCKON=restipsum.com,443,NULL,s-S.Skip CA-S.Skip CA-S.Certificate Error:19-S.ERROR:74:Failed to open socketERROR!Status = 13>>Socket connection error #spwf04sa #socket #certificate #tls #encryptionWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
