2015-12-21 2:26 AM
I'm trying to decode/encode my packets using manchester code. Is it possible to use on-chip encoding and decoding for this IC? I couldn't find any register in datasheet, so I assume it's not possible but maybe there's some hidden registers which are able to do it. Any help would be appreciated.Regards,Robert2016-01-12 12:45 AM
SPIRIT1 does not support manchester encoding/decoding natively. It only supports it in the WMBUS submodes that require it. I attach here a simple .c file that contains the manchester encoding/decoding routines from a raw buffer. Regards, F. ________________ Attachments : manchester.c : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Ht36&d=%2Fa%2F0X0000000aJI%2FJX0i0SWj5gsDevxtwwOWV20aX41WuoSHRo.TmubZxhI&asPdf=falseWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
