2016-04-04 12:50 AM
Dear Madam, Sir,
Would You inform me about the type of crystal what SPSGRF board uses.I have developed and manufactured 250pcs Spirit1 boards with this crystals.http://www.ndk.com/images/products/catalog/c_NX3225GA-STD-CRG-1_e.pdf
All my boards with my radio able to communicate to each other using FC_OFFSET1 = 0 and FC_OFFSET0 = 0 value. But those boards which area mounted the buyed SPGRS can't communicate with my radios. I know a can tune syntesizer of SPSGRF boards to my requirement.Can You garantee that the your SPSGRF boards will mounted the same crystal in the future? Need I check all buyed SPGRS modul crystal tolerance during manufacturing process all the time in all modul?Thank Your answare in advance Laszlops.My radio params are#define XTAL_OFFSET_PPM 0 #define CHANNEL_SPACE 250000#define MODULATION_SELECT GFSK_BT05 #define DATARATE 250000 #define FREQ_DEVIATION DATARATE/4 #define BANDWIDTH DATARATE *12/10We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
