2021-12-17 11:08 PM
we are trying to program a hex file by using st link v2 programmer in cube programmer getting follow error.
no stm32 target found.
also I updated the firmware.
the target board is working with another st link.
from not working st link we are getting TCK but TMS not getting.
may be what is issue ?
2021-12-18 5:29 AM
Tripple check wiring, try connect under reset, try other debuggers or debug-programs for the stlink.
2021-12-18 5:49 AM
The failing ST-LINK is a dud?
Could be damaged at connector or cable.
Try a lower connection speed.
What type of STM32?
2021-12-19 9:52 PM
thank you for reply
we connected with 240kHz low speed only.
cable is working fine.
we tried with stm32h750 MCU.
here which connector we need to check ?
2021-12-19 9:53 PM
thank you for reply
we checked with other stlink programmers and working fine.
we tried under reset mode only and all wiring has fine.
