2025-10-03 9:11 AM
We have followed single conversion mode as outlined in: L9966 lambda sensor interface – rev. 1.0.0 1 L9966 lambda sensor interface Application Note. But the result register is all zeros.
Is there anything missing?
The register nameing is not consistant datasheet has DWT_VOLT_SRC_LSF_CTRL, but app note DWT_VOLT_SRC_CTRL.
The sequencer mode works fine.
2026-03-05 11:32 AM - edited 2026-03-05 11:32 AM
If the question is still relevant:
If the sequencer mode works but single‑conversion mode always returns 0x0000, there are typically a few configuration points to double‑check:
Hope that (still) helps?
/Peter
/Peter
