2018-06-07 12:21 AM
I'm using a SPWF04SA wifi module.
When I create a file (for example sample.json) with AT+S.FSC command the module saves that file in its ram memory.
How can I save that file in the internal or external flash memory ?
Thanks in advance !
#ram #wifi #flash-storage #spwf40sa #fileWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
