2018-11-26 2:31 AM
2018-11-26 2:42 AM
Hi Patrick,
could you detail your use case?
Thanks,
Elio
2018-11-26 3:02 AM
Hi Elio,
the SPWF04 is configured as MiniAP and when the smartphone is connected to the mini AP:
Automatically a web page open on the smartphone
Best regards
2018-11-26 3:31 AM
So, you want to implement something like a captive portal?
2018-11-26 4:34 AM
Yes exactly,
How configure the SPWF04 for that?
Regards,
2018-11-27 12:14 AM
Hi Elio,
I configure the SPWF04 like this:
-ip_apredirect= stra.html (my Web page)
but that don't work! (No page found at captive portal)
What are the parameters to configure the captive portal?
Best regards
2018-11-29 12:42 AM
Hi Patrik,
it seems not possible to enable this feature because the DNS on SPWF04 only respond to requests for the domain specified in ip_apdomainname.
The smartphone make several DNS and http requests before opening the popup and all must be served otherwise the popup is not opened.
ip_apredirect specifies the page that must be sent when the default page (http://<SPWF04's IP>/) is opened.
