2023-04-04 11:07 PM
is the drivers to configure BLUENRG-2 and BLUENRG-2N are the same ?
can i use the same driver from x-cube-ble2 to make an application with BLUENRG-2N ?
Thank you.
2023-04-05 7:26 AM
Hello @malarab,
I am not a BlueNRG expert, but you can check the BLUENRG-2 AND BLUENRG-2N document.
Regards,
Chahinez.
2023-04-05 7:26 AM
Hello @malarab,
Regards,
Chahinez.
2023-04-12 2:40 AM
hi @ChahinezC
it is not clear in the documentation,
i already started the implementation but it is not working yet !
I don't know if it can be a problem in the compatibility of the driver with the hardware.
Thank you,
