2014-09-17 4:24 AM
I'm wondering if there is some possibility that BlueNRG (which has established connection - slave role) will produce non-connectable advertising (same as device C at Bluetooth 4.0 core spec. Vol1, Part A, 4.1.2)? After sending ''LE Read Supported States'' command, I get result (0x00000000130000FF) which tells us (according to Bluetooth 4.0 core spec. Vol2, Part E, 7.8.27 ) that Non-connectable Advertising State and Slave Role combination is not supported Thanks for any advice. BR Matej #advertising #bluenrg2014-11-17 7:20 AM
Hi Matej,
as you say, the BlueNRG cannot support the state: ''Non-connectable Advertising State and Slave Role combination''. Regards, GraziellaWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
