BlueNRG-2N : lis_is_empty then reach timeout
malarab
Senior II
I configure the BlueNRG-2N,
On initialisation -> hci_reset -> hci_send_req ->
after send_cmd
the (!list_is_empty(&hciReadPktRxQueue)) is stell false and the timeout is reach
i thing is something about pointing received data to the event list (or not !)
any suggestion ?
thank you,
1 ACCEPTED SOLUTION
Accepted Solutions
malarab
Senior II
it was a problem on powering the device : LDO config was not correct (wrong value of inducatance)
1 REPLY 1
malarab
Senior II
