Sending TXT files through uart
Hi,I'm trying to know how can I send a txt file through UART protocol to a Bluetooth module so I can transfer data wirelessly to a pc.I could read line by line sending it continuously, but I wanted to know if I could send it as a file that I could th...
jreis.1 by Associate II
  • 3846 Views
I am doing i2c code with multiple slaves but one of slaves which is vcsel laser driver only contain 11 bit, 3 for address and eight memory I have no idea how to communicate and tell it to emit laser. I am trying to use memory address 001b.
datasheet: https://www.ti.com/lit/ds/symlink/onet4291va.pdf?HQS=dis-mous-null-mousermode-dsf-pf-null-wwe&ts=1665641656738&ref_url=https%253A%252F%252Fwww.mouser.com%252F
ACart.1 by Associate III
  • 3917 Views
Difference between STUSB1600QTR vs STUSB1600AQTR?
Hi,As STUSB1600AQTR is currently out of stock everywhere, we have sourced from a secondary source the STUSB1600QTR part number. The datasheets seem almost identical, so we expected the part to be a drop-in replacement. However, this is not the case a...
RTsch.2 by Associate
  • 1457 Views
VBUS monitoring not working on STUSB1602
Hi guys ! I am trying to implement a USB-C powering and communication between 2 of my devices. There is no Power Negociation implemented yet. The default voltage is 5V.I want to make sure my source device is safe so I would like it to shut down VBUS ...
VSpad.1 by Associate II
  • 1498 Views
STUSB4500
Can the STUSB4500 support a USB C DRP and USB PD (sink-only) application using the SOM OTG interface illustrated above? Can it drive the VBUS, OC, and ID inputs and receive the EN output? We would like our product to serve as USB UFP (device), USB DF...
EHD by Associate II
  • 1288 Views
