BlueNRG chips paired after very long time – about 15-20 seconds instead of 5 seconds, as it should be with a good chip.
We found in a LOT # T2N15KQN0001, which includes 3000 BlueNRG chips, that 300 (10%) are paired after a very long time, (15-20 seconds) while all the other paired after 5 seconds only.When changing the CPU, the problem is fixed - the CPU environment i...
ShaiK by Associate
  • 755 Views
SPI slave not reading the data in first run
Hi all, i got to know a bug/problem/issue in SPI communication. one of my colleague is working on designing controller(complete SDK), he has an issue, the issue is, whenever he writes the data from master it writes properly, but when trying to read t...
meghasb by Senior
  • 977 Views
Very low power camera
What is the lowest power cameras available? MIPI or other interface.Super crystal clear image is not important, but something in range of 1 megapixel or more required.Most i've searched are in order of half watt. Which is a lot.Can anyone point me to...
WojtekP1 by Associate III
  • 896 Views
