Wireless M-Bus stack
Posted on September 29, 2016 at 13:06Dear Support Team,I want to collect data from 64  heat meters, heat meters are from Danfoss, in mode T1.The purpose of the project is only data collecting from heat meters without decryption, collected data forwa...
klevente by Associate II
  • 690 Views
spwf01 module Timing Issue
Posted on September 01, 2016 at 12:45Hi,I observed followings while communicating between two spwf01modules: At the Client side when its try to connect to server I’m using AT+S.SOCKON command to connect. In this command I can pass “ind�? parame...
BlueNRG return/error codes?
Posted on August 29, 2016 at 15:09Hi. I`m implementing BlueNRG based Eddystone beacon. And i have to check GATT Return/Error codes of GATT read/write commands in Android/iOS application. I have no idea about this codes and i found no BueNRG API fun...
Output.cgi and httpdfsupdate
Posted on September 13, 2016 at 14:00Hi I have an issue similar to one raised earlier in the forum but there didnt appear to be a resolution.When I create my own web pages and use the output.cgi as per examples I have found, when I submit the data f...
AP and miniAP difference
Posted on September 12, 2016 at 11:14Hi,I have doubt, what is the difference between AP(Access point) and miniAP.Is there any functionality difference?Is there any less functionality in miniAP compare to AP?Thanks Basavanagouda
I can't send many packets through BlueNRG
Posted on September 07, 2016 at 12:00Hello, I'm using the ST BLE (SPBTLE-RF) to send data from MCU to smartphone. We used an entire solution from ST (VL53L0X sensor, STM32F401 MCU and SPBTLE-RF BLE). I want to send many packets (a lot of data, >50...
chahir by Associate
  • 579 Views
GATT char update value, store in EEPROM
Posted on September 07, 2016 at 10:59Hello, I am using Blue NRG along with L051. I have used GATT_char_update_value for changing the GAP device name from default 'BlueNRG' to something taht I want. I am using nRF Master Control application on an and...
sai by Associate II
  • 702 Views
