Questions on the S2-LP transceiver
Posted on June 20, 2017 at 11:26Hello,we are designing an RF interface for the ISM 868-870 MHz band.We are attracted to the S2-LP transceiver mainly because it drains only 10 mA at 10 dBm RF output powerI got a couple of questions about the S2-LP tr...
S2-LP Sigfox Application
Posted on December 15, 2017 at 10:05Hello,I am trying to develop a Sigfox application with the S2-LP transceiver.I bought the STEVAL-FKI868V1 evaluation kit and I downloaded the STSW-S2LP-SFX-DK software.Everything works well with the kit, but now I...
L J by Associate
  • 880 Views
First Time Connection SPWF04SA - Faild ,please help
Posted on December 12, 2017 at 22:52Hello running the example code  : WIFI_Example_Client_Socketusing SPWF04SAalso the server program in the st utility ip 10.0.0.1 (checked with external socket.exe and worekd)but the WIFI_Example_Client_Socket  moo ...
maor by Associate III
  • 793 Views
SPWF04SA ST COMMAND PDF ?
Posted on December 12, 2017 at 22:59Hello ,we would like to use the wi fi  SPWF04SA as stand aloneusing in uart1/ where can i find short simple l example code script ..setup sid ,key.....open socket ip/port send hellow word , and close socket ?2.whe...
  • 1115 Views
SPWF04Sx FW Source
Posted on December 12, 2017 at 14:19Is $SUBJECT available ?Given the absence of detailed SPI protocol descriptions (and the problems I face), I'd love to read the source.I'd like to implement a custom RTOS task on the module. I don't need microphyth...
BLUEnRG-1 mass production
Posted on December 13, 2017 at 09:51Hi All,We are using BLENRG-1 for TAG, the BLENRG-1 act as slave and connected to another MCU, The BLENRG-1 containt just the BLE-STACK, i have few questions regards to BLUENRG-1 and mass production:1- Did the BLUN...
Nav Dev by Associate II
  • 796 Views
Delete address from security_db
Posted on November 08, 2017 at 17:45Hello,I have differents slave devices bonded to a master device, I would like to remove a unique address currently bonded to that master device, is it possible to do it without using the aci_gap_clear_security_db(...
jampino by Associate III
  • 2317 Views
