Extending the connector of the VD56G3
dluka
Associate II
I am using the VD56G3 connected to a STEVAL-CAM-M0l1.  There is a very small ribbon cable between the sensor and the connector on the CAM-M0l1 - roughly 5mm.  I am working on a mock-up of some smart glasses where I'd like to extend that cable to a considerably longer length - ideally 1 meter.  Is there a way to create an extension to this cable or a product that has a lengthened connection?
I know that there is also a ribbon cable from the STEVAL-CAM-M0l1 which could easily be lengthened, unfortunately, the form factor of the STEVAL-CAM-M0l1 is not suitable for my mock-up.
Any suggestions/recommendations as to how to lengthen this connection along with any pitfalls would be appreciated.
Thanks,
Dan Luka
1 ACCEPTED SOLUTION
Accepted Solutions
CyrilTechPro
Hello Dluka,
you can do an extra ribbon to connect camera module you can find the pinout of the connector here: https://www.st.com/resource/en/schematic_pack/steval-cam-m0i-schematic.pdf
be careful 1 meter is long flex I'm not sure you will be able to send data through a ribbon of 1 meter (interference, attenuation ...).
You can find the camera module connector  :
https://fr.farnell.com/hirose-hrs/bm28b0-6-30ds-2-0-35v-53/conn-empilable-fem-30s-2p-2-rangs/dp/3361101
https://fr.farnell.com/hirose-hrs/bm28b0-6-30dp-2-0-35v-53/conn-empilable-30s-2p-2-rangs/dp/3361099
Don't hesitate if you have any other question
Regards,
Cyril
1 REPLY 1
CyrilTechPro
Hello Dluka,
Regards,
Cyril
