2025-10-07 12:50 AM
What's the difference between the following sensor variants:
From what I've seen from going through the available product documents, they are all the same, performance-wise (range, frequency, FoV etc).
Difference between the CH and CX seems to only be the firmware with the CH being able to output histogram data?
Is this correct?
Can the CH still output the normal processed data?
2025-10-07 5:50 AM
Hello
Indeed, main difference is the firmware.
You can output compact and normalized histogram with te CH that you cannot with the CX.
The L7CH is also outputting processed data too.
Anne
2025-10-07 5:50 AM
Hello
Anne
