Cover window guidelines for the VL53L3X - not like VL54L1 and VL53L0, we can not find the document for cover window design of VL54L3x - Please help to advise - ref for VL53l1 "ong-distance ranging Time-of-Flight sensor"
PTran.3
Associate
1 REPLY 1
John E KVAM
The coverglass requirements for the L0, L1, L4 and L3 are identical.
I use
https://community.st.com/s/article/Time-of-Flight-Cover-glass
as a starting point for all of them.
The only trick is that the L1X and L1CB are 0.5mm taller, so if you go to hornix.com.tw and purchase a coverglass the part number is slightly different - to account for the added height.
Otherwise the documents are interchangable.
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
