Imaging (sensors)
VL53L1X strongest / nearest reflector
Is there any way to configure the VL53L1X sensor to deliver either the strongest or nearest reflector (reflector at closest distance) ? The latter case would be preferrable for our application scenario.
mf101 by Associate II
  • 1514 Views
VL53L1X ambient rate drops with better target reflectance
It looks like the ambient rate delivered by the sensor drops, the better the reflector is (the higher the signal rate is). In a practical evaluation the ambient rate dropped from 40 kcps to 0 kcps when the signal rate increased from 400 kcps to 12000...
  • 1274 Views
How to interface the VL53L3CX with an ESP32
Hello, I am trying to connect a VL53L3CX (a module I purchased on AliExpress) with the ESP32. I have found the Arduino library but it does not fit the ESP32. I will highly appreciate your help in helping me get this working. Thanks a lot, Motti
MBaza.1 by Associate II
  • 6134 Views
VL53L1CB Low Ranging Performance and Flickering
Hi,I designed a sensor array containing multiple VL53L1CB sensors. They are configured to scan a 3x3 grid inside its view with multizone scanning. That works great at small distances but suffer a distances above ~1,5m.Experimentation shows that the s...
dlux by Associate II
  • 6204 Views
  • 12 replies
Resolved! Printing Garbage Value
Hi there,I am working with tfmini lidar and i am using USART3.However i am getting the garbage in the virtual port any idea how can i resolve this but i am getting the right header i.e YY in decimal. Any suggestion would be appreciated.Thanks
