Imaging (sensors)
How to work with the VL53L5CX if you don't have enough memory?
Hello,My name is Joran, and I'm a student in Belgium. My school tasked me with a project that involves the use of the VL53L5CX sensor.Aside a few other guidelines, I have to follow this rule: no use of high-level programming languages (e.g. Python) o...
JVan .7 by Associate
  • 1573 Views
VL53L1 interrupt problem
Hello.Isn't the period of interrupt not in timing budget?When tested indoors, the period of the interrupt is the timing budget.However, when testing outdoors, the interrupt cycle is irregular.If you look at UM2133 - Rev 6 page 11, what is reported wh...
joh.5 by Associate II
  • 1253 Views
Resolved! About driver for VL53L1X
Dear Sir, ​We will develop system with VL53L1X. Now we are going to port the driver for our Thread RTOS. There are several sample version at candidates such as STSW-IMG007, STSW-IMG009 , STSW-IMG013 and STSW-IMG032. Could you give me some advice f...
DSai.1 by Associate III
  • 1649 Views
VL53L5CX Custom PCB won't work.
I've been trying to design a custom board for a VL53L5CX ToF Sensor similar to a VL53L5CX-SATEL or the ones made by SparkFun and Pololu. I didn't want to use the GPIO Pins or I2C reset to simplify my project.I tried this design. However, I cannot rec...
baris1 by Associate
  • 1249 Views
Vl53L4CD ULD SetTimingRange not works
I am started to work with the sensor, and when I tried to calibrate based on the documentations I fond that I when i use the SetTimingRange function (as shown ind the high accuracy example ).I tried to error check with the GetTimingRange function and...
BLuka.1 by Associate
  • 1347 Views
Where to locate missing windows.h files for VL53L0X API?
Where to locate missing header files for VL53L0X API?Hi allI am currently trying to integrate the VL53L0X sensor to a STM32L053 discovery board using CubeMX and Cube IDE, but I haven't had the best of luck...I am inexperienced regarding the integrati...
MGryb.1 by Associate
  • 3742 Views
