Teseo and NMEA messages
PCu1
Senior
I'm currently playing with the X-NUCLEO-GNSS1A1 kit and I have two questions:
-If I only configure Galileo the messages are still GPGLL and I do not get GAGLL for Galileo and I do not know why?
-The Teseo Suite allows you to filter messages eg xxGLL, but can you directly configure the module to limit the type of message sent by usart?
Thank you,
Pierre
1 ACCEPTED SOLUTION
Accepted Solutions
Francesco Virlinzi
Hi Pierre
Whatever the constellations enabled the module Teseo-LIV3F always sends the GPGLL message.... It's hard-coded in the code.
Yes. Sure.
On each port there is linked a 64bits-bitmaps to specify the messages allowed on the port.
In this way you can select the message you really want.
To configure the UART-message list you can use the scripts:
$PSTMCFGMSGL,0,1,<32bits_list_low>,<32bits_list_high>
$PSTMSAVEPAR
$PSTMSRR
To configure the I2C-message list you can use the scripts:
$PSTMCFGMSGL,3,1,<32bits_list_low>,<32bits_list_high>
$PSTMSAVEPAR
$PSTMSRR
For the 64bits values meaining have a look to the CDB-201 and CDB-228 in the SW user manual online
Hope this helps
Francesco
2 REPLIES 2
Francesco Virlinzi
Hi Pierre
Yes. Sure.
$PSTMSAVEPAR
$PSTMSRR
$PSTMSAVEPAR
$PSTMSRR
Hope this helps
Francesco
PCu1
Senior
Hi Francesco,
Thank you for your quick and complete answer.
Pierre
