2019-01-03 1:03 AM
Please note that STM32CubeMX v5.0.1 is available on the web since yesterday.
The main updates in this minor release are the following:
You can either upgrade your current STM32CubeMX version to 5.0.1 or install 5.0.1 version directly from st.com as follows:
If you want to install the Artifical Intelligence pack through STM32CubeMX:
If you face any issue with this new release, you can submit your question in the STM32 Q&A space using the relevant topics:
2019-01-08 10:47 PM
could you please release the source code for the static library `network_runtime.a`.
By the way, CubeMX generates an incorrect Makefile on macOS. That is, the path in the Makefile is not correct and I have to manually edit it to get it compile.
The documentation for x-cube-ai is very poor.
2019-09-29 11:06 AM
I was following the ST video course on Cube-AI https://www.youtube.com/watch?v=6oTkHylHssQ&list=PLnMKNibPkDnFiQd11pDFtDL2aqUZHTjto&index=5&t=0s
In this video, Can you share this code if you have it please?
I have noe idea how to get the dataset using the example code mentioned in the video, 'import tutacousticscenes2016'
