2026-02-27 5:43 AM - last edited on 2026-02-27 6:49 AM by Andrew Neil
Dear ST Technical Support Team,
I am currently developing a voice recognition application on the STEVAL-STWINBX1. I trained a classification model using the notebook:
Utilities\AI_Resources\TrainingScripts\UltrasoundClassification\UltrasoundClassification.ipynb
In the notebook/off-target evaluation, the model achieves >90% accuracy, but after deploying to the MCU the recognition accuracy becomes very low.
To investigate, I used STM32CubeMX → Validation on Target. However, the validation process fails with the message: “Automatic build and run failed” (Automatic Validation on the target)
Thank you for your help. I look forward to your guidance on resolving the validation failure and improving on-MCU accuracy.
Best regards,
dzf
2026-03-04 5:00 AM
Hi @dzf,
I have no knowledge about this notebook.
I would say that it is pretty deprecated.
The main ways to do AI for STM32 is now to use the tools that you can find here:
Edge AI solutions overview - STMicroelectronics - STM32 AI
In your case, I would suggest to look at the ST Model Zoo Services and the audio use cases.
Have a good day,
Julian
2026-02-27 6:52 AM
@dzf wrote:Dear ST Technical Support Team,
You realise this is a Community forum - most contributors are not ST Staff ?
If you want direct support from ST, open a Support Case at https://ols.st.com/s/
You could also contact you local FAE: https://www.st.com/content/st_com/en/contact-us.html
2026-03-04 5:00 AM
Hi @dzf,
Have a good day,
Julian
